Date/Time: Thu, 06 Feb 2025 15:18:38 +0000
Stock Symbol Search
View Count: 858
[2020-05-03 05:52:37] |
CMG - Posts: 179 |
Hi There, When trying to search for a stock symbol with File>Find Symbol>Stocks>NYSE... and entering the text in the "enter search text below" and searching by either search by symbol or search by description no symbol comes up and a line on the top of the window appears that says "[Requested Additional Symbols]. Thank You |
[2020-05-03 23:37:12] |
We are not observing any problems ourselves when we search for BATS symbols. Do you still notice a problem at this time?
[2020-05-03 23:44:21] |
CMG - Posts: 179 |
Working now.
[2020-05-03 23:45:28] |
It must have been a temporary problem due to no symbols being provided on the Barchart Open Feed at the time you encountered this.
