Date/Time: Thu, 06 Feb 2025 14:54:37 +0000
[User Discussion] - Number Bars - Independent Percent Compare Threshold for Backgound type and Text
View Count: 1264
[2020-05-03 04:24:36]
Meklon - Posts: 223
Hello Support,
Is it possible to add separate option in settings of Number Bars to independently assign Percent Compare Threshold for color method of Background Type and Text?
At the moment it is only possible to Use Separate Colors for Text Coloring Method of Column 1, but it still following parameters set in Column 1 Percent Compare Threshold.
I would like to accomplish the following:
Color Schema - 1
Column 1 Number Bars Text ---> Bid Vol x Ask Vol
Column 1 Background Type ----> Ask / Bid Volume Split Profile
Column 1 Background Coloring Method ---> Based on Diagonal Dominant AskVol BidVol ToVolume At Price Percentage
Column 1 Text Coloring Method ----> Based on Diagonal Dominant Side AskVol BidVol ToVolume Percentag
Use Separate Colors for Text Coloring Method --- Yes
Color Schema - 2
I am able to use above settings independently of each other and they work properly but if combined together the coloring of the Ask / Bid Volume Split Profile is not working correctly as it appears to be controlled by the same settings of "Column 1 Actual Compare Threshold" parameter (please see attached slides)
imageCorrect-Profile-coloring.png / V - Attached On 2020-05-03 04:23:43 UTC - Size: 9.25 KB - 297 views
imageIncorrect-Profile-coloring.png / V - Attached On 2020-05-03 04:23:51 UTC - Size: 9.6 KB - 273 views
