Date/Time: Thu, 06 Feb 2025 15:30:50 +0000
IB Server Side Orders
View Count: 665
[2020-05-03 00:31:28] |
TraderD - Posts: 56 |
I'm using IB with SC data. Do you recommend checking or unchecking both "Use Server Side OCO Orders" and "Use Server Side Bracket Orders" in General Trade Settings? Thanks.
[2020-05-03 02:37:00] |
Definitely keep this enabled: Use Server Side OCO Orders Using server-side bracket orders probably should be enabled but if you have some kind of problem with them disable the option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-03 02:37:13
