Date/Time: Thu, 06 Feb 2025 18:15:34 +0000
expanding historical data
View Count: 554
[2020-05-02 22:34:18]
startledbymoth - Posts: 39
I'd like to see more historical data in my daily chart, see attached. As you can see, I have set the "days to load" at two years; however, the "From" field in Date Range in File will not permit more history beyond just under a year. Please suggest how I can expand what history this chart displays without disrupting the settings on related charts, thanks.
imagedaily.JPG / V - Attached On 2020-05-02 22:33:17 UTC - Size: 586.09 KB - 278 views
[2020-05-03 23:40:54]
You cannot get what you want with MES. And if you do not know why, then ask the exchange. You need to use the ES futures contract instead.
Date Time Of Last Edit: 2020-05-03 23:41:02
[2020-05-06 18:27:23]
Of course!
Thanks...
But tried again using ES and same result: historical data will not fill past a few months or a year at best -- please advise, thanks
[2020-05-06 21:13:54]
Follow the instructions here:
