Date/Time: Thu, 06 Feb 2025 15:09:25 +0000
Sierra Chart and Rithmic
View Count: 730
[2020-05-02 20:25:11] |
JEM.TRADES - Posts: 16 |
Hi guys, I've been using Sierra Chart with Rithmic for a while now. Given the recent changes made by the CME, what should Sierra Chart customers using Rithmic know in the upcoming weeks and months? What measures should we be taking? Thank you! |
[2020-05-03 09:30:52] |
Refer to: Regarding Rithmic (Our Final Post on this Subject) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-03 15:06:10] |
Thanks, after reading the post I have one concrete question: Can I use Sierra Chart with data coming from Rithmic if I don't open R Trader at the same time? If yes, will this continue to be possible in the future? What about after December 31,2020? The reason why I insist in using Rithmic is because I'm working with a company called OneUp trader to get a funded account and they only use Rithmic Thanks for the support |
[2020-05-04 00:09:50] |
Can I use Sierra Chart with data coming from Rithmic if I don't open R Trader at the same time? Yes.If yes, will this continue to be possible in the future? What about after December 31,2020?
The safest answer we can simply give is no after December 31, 2020. But by then we hope that One Up Trader adopts our alternative to Rithmic. So this becomes a nonissue at that time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-04 00:10:25
