Date/Time: Fri, 03 Jan 2025 03:18:55 +0000
Adjusting Date Labels for Globex Session Intraday 1 day bars
View Count: 627
[2020-05-02 20:17:51] |
hanro - Posts: 10 |
When using Daily Historical Chart, each bar's date labels on the bottom of the chart are showing as desired: Mon, Tues, Wed, Thur, Fri But using 1 day Intraday Chart and reverse session time of 18:00 - 17:59, the bar's date labels are showing as Sun, Mon, Tues, Wed, Thur, which is a little confusing because the Thur label is actually the end of Friday's session (and there is no Fri label, it starts next week on Sun). Is it possible to configure the Intraday Chart 1 day to display the labels like the Historical Chart? I want to capture the entire Globex Session from start to finish but have the date labels reflect when the session ends instead of when it starts. I've attached a few screenshots of my configuration. http://www.sierrachart.com/image.php?Image=1588450118438.png http://www.sierrachart.com/image.php?Image=1588450171812.png |
2020-05-02 15_38_44-Sierra Chart 2092 ES Interactive Broker.jpg / V - Attached On 2020-05-02 20:14:07 UTC - Size: 272.6 KB - 270 views |
[2020-05-03 10:16:03] |
This cannot be changed: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
