Date/Time: Thu, 06 Feb 2025 17:03:06 +0000
How to set Chart Time to Local to Exchange Time or Local Time
View Count: 662
[2020-05-02 00:52:59] |
Nathan_Vallinger - Posts: 5 |
1) In Tradestation I can choose Exchange time or Local time for the chart. In Sierra Chart, I could not find where to set. If you look at my attachment (chart), market closed but time it shows as 20:59. Help me with the Session time settings for NQ, ZB(US), RB and GC 2) When I am on a chart and right click and choose "Chart Values/Crosshair", I am able to move from bar to bar. I would like see Bar's info some where on the chart while I am "moving" my Char Values/Crosshair from one bar to next bar. 3) Can somebody provide me Active Traders Workspace which contains, charts and DOMS. 4) I subscribed for Level 5 package. I need sample worksapce/chart windows to use those features. Can someone help me provide me workspace using the Number Bars, Market Delta. I followed youtube videos, and tried to make one, had some challenges. 5) I am sorry I am comparing Tradestation with SC. I am going through my learning curve,please bear with me. Please help me with this request. Date Time Of Last Edit: 2020-05-05 13:01:15
[2020-05-05 13:01:11] |
1) Refer to the following documentation for information on Time Zones: Time Zone Setting 2) Refer to the information here for the Tool Values Window and the section below it for the Compact Tool Values Window: Chart Drawing Tools: Tool Values Window 4) There is an example Numbers Bars chart here: https://www.sierrachart.com/AdditionalFiles/NumbersBarsExampleChartbook.cht Refer to the information here for how to use it: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-05 13:17:20] |
We see you are using CQG and we definitely do not recommend that and recommend that you change to the order routing service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
