Date/Time: Thu, 06 Feb 2025 23:38:46 +0000
Bar Time Matching Method...best option, intraday
View Count: 650
[2020-05-01 21:40:12] |
User681150 - Posts: 62 |
i have a 5 minute chart. I use use the overlay study to bring it onto a 1 minute chart... for the most timely and accurate reading in real-time, what are the best settings? Data Copy Mode:? Bar Time Matching Mode:? thanks Date Time Of Last Edit: 2020-05-02 03:59:30
[2020-05-02 10:53:46] |
Refer to the documentation for the settings here: Study/Price Overlay Study: Data Copy Mode Data Copy Mode should not matter in this case. Bar Time Matching Mode = Containing Match Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-02 10:55:44
[2020-05-13 20:46:20] |
i can find the documenttion i didnt post because i could not find the docuemntation.<p/>i posted cause i couldnt understand the options and what you meant by it why doesnt copy mode matter "in this case" |
