Date/Time: Thu, 06 Feb 2025 15:27:12 +0000
LMAX
View Count: 518
[2020-05-01 20:14:27]
phaedonk - Posts: 352
It works fine, thank you.
The only issue I am having is the position may appear wrong depending on the days loaded in the chart. I understand LMAX does not give the position and SC calculates it via the trade fills. I also understand the solution you provide via Advanced chart settings.
I was just wondering if there is a way for the position to be calculated independently of the days loaded in the chart (seeing as the trades are not affected in the Trade Activity Log)?
[2020-05-02 02:49:44]
You just need to set this setting which removes the reliance on the days loaded in the chart:
Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu)
