Date/Time: Thu, 06 Feb 2025 17:59:36 +0000
an .SetChartStudyValues(int ChartNumber, int StudyID) input cannot be saved as default
View Count: 523
[2020-05-01 19:54:10] |
Zosimus - Posts: 345 |
Hi SC team, I have a study with a few inputs. One of the inputs if of the sc.Input[].SetChartStudyValues() type. When I save the settings of the study as default all inputs are saved except this specific input. |
[2020-05-06 08:43:53] |
We will be working on a new implementation for saving default study settings. This problem will be resolved then.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-06 08:44:00
