Date/Time: Thu, 06 Feb 2025 15:14:46 +0000
DOM not displayed correctly for CME Micro FX contracts - Denali
View Count: 579
[2020-05-01 19:47:37]
T44 - Posts: 363
The E-Micro British Pound and E-Micro ECU are showing a bid/offer crossed at 0.0001 via the Denali feed. (M6BM20_FUT_CME and M6EM20_FUT_CME)
Version 2092.
Thanks.
[2020-05-02 02:50:41]
We are not understanding what this means. We had a look at the market depth data for the symbols and see no observable problem.
If you are using a sub instance, and using the option to control the number of market depth levels subscribed to, that does not work properly. You need to update to the latest prerelease because it will ignore any depth limiting settings between sub instances.
