Date/Time: Thu, 06 Feb 2025 15:20:09 +0000
data sierra chart
View Count: 533
[2020-05-01 17:45:54] |
User149924 - Posts: 2 |
hi i conctat you for know if you have a solution "trading plateform+ only data real" for the market charting. no Exchange with my broker. i don t connect sierra chart at R trader,consequently i will pay two exchange at the CME. thank you |
[2020-05-01 18:40:33] |
In the case of when using Rithmic, based upon what you are describing, you would need to pay two exchange fees. If you do all the trading from Sierra Chart, you will not need to. Sierra Chart does have full trading capabilities: Overview of Trading Also be aware of this service which is a good alternative to Rithmic: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-01 18:40:59
