Date/Time: Thu, 06 Feb 2025 15:04:17 +0000
Market Depth Window Only Displaying One Line
View Count: 469
[2020-05-01 16:43:35] |
bizywoman - Posts: 6 |
I am using version 2088 and when I open Market Depth Window it only displays one line (the most current price), The Total (1), and %. I used to be able to see 10 levels. What has changed? How can I fix this? Thanks.
[2020-05-01 18:31:29] |
You need to login to the Support Board with an active Sierra Chart account in order to get help. In Sierra Chart select Help >> Support Board to do this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-01 18:31:34
