Date/Time: Thu, 06 Feb 2025 14:57:12 +0000
Dorman
View Count: 556
[2020-05-01 16:00:56] |
Robert Wojczak - Posts: 147 |
I am opening an account with Dorman trading . I am going to be using your data feed for charting and trading. I want to have the charts up on my main computer and the execution platform on my laptop. Will I be able to do this. Can I run 2 instances of SC. I dont like web based applications. Thanks Rob |
[2020-05-01 18:07:26] |
You can run 2 instances of Sierra Chart without any issue. The only thing you need to be aware of is the data feed. If you are not accessing the data from both systems at the same time, then there is no issue. But, if you want to access the real-time exchange data from both systems at the same time, then be aware of the restrictions that are put in place by the exchanges and you will have to pay the exchange fees a second time for the second connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-01 18:08:06
[2020-05-01 18:20:19] |
So lets say I want the charts on my main computer and an execution platform on my laptop I would need a separate CME feed for both. So whatever the the non depth of market feed is 3.25$ is. Do I need to pay the Denali feed 2 times?
[2020-05-01 18:32:51] |
You would just pay the 3.25 twice. This is all. It only applies to the CME fee.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-01 18:34:56
[2020-05-01 18:35:45] |
Great Thank You
