Date/Time: Thu, 06 Feb 2025 15:01:36 +0000
Get notified on specific condition through watchlist using NumberBars
View Count: 539
[2020-05-01 11:34:28] |
jasongleamour - Posts: 25 |
Hi, As I read from the support forum it is possible to get alert on NumberBars when a apecific condition is met. My NumberBars currently only shows "Bid Vol x Ask Volume", and my NumberBar Chart period is 3 min. I would like to get notified when "Bid Vol x Ask Bolume" is the most among X number of bars/candle. (The formula should not be complicated for a novice user but I am not, I am trying to learn.) 1- Is it possible to get notification in above condition? 2- Is it possible to get notified for all the instruments on the watchlist, when the above condition is met? 3- Are the alert system server side or SierraChart client should be running on the local machine? I would really appreciate feed back on this. Thank you |
[2020-05-02 19:10:04] |
I have been searching and found Volume at Price Alert v2, it seems to be doing the job for my task.
