Date/Time: Fri, 13 Nov 2026 14:33:00 +0000
Heiken ashi spaces
View Count: 1154
| [2020-05-01 01:22:20] |
| User453937 - Posts: 3 |
I can't figure out how to get these white spots out of the heiken ashi on my tick charts. Can you help? Also, is there a way to get the open & close (currently black) to the same color of the heiken ashi (red or green)? |
| [2020-05-01 07:22:32] |
1. This is caused by a study. You need to enable this option for that study to not cause it to give that effect: Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region) 2. Refer to this setting: Graphics Settings: Color Entire OHLC Bar the High/Low Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-01 07:23:38
| [2020-05-04 18:12:00] |
| User525965 - Posts: 180 |
Thanks changing the global settings removed the white space on the bars, but i'm unable to remove the black lines (they look like open & close lines) but there already area red and green open/close lines as well. Not sure where the duplication is coming from and why there are 2 of each that don't match...
