Date/Time: Thu, 06 Feb 2025 14:05:06 +0000
SC connected to Rithmic via the bridge - No Plugin - Monthly CME Fees Doubles or Not
View Count: 629
[2020-04-30 22:47:20] |
User631345 - Posts: 36 |
Hi, I use SierraCharts as my trading platform and Rithmic as my data feed. Sierra connects to Rithmic via the bridge provided by Sierra. Have a simple question. In light of the new CME Monthly data fees, will I be charged twice for data fees ? Note : I use only 1 Trading platform ie Sierra Charts and make the connection to Rithmic only via the bridge Reason I ask this basic question is because there is a mention of a plugin that one needs to connect to Rithmic. I dont use that and neither do i know how to use it and if at all it is required in my situation Would appreciate if you could clarify this for me Kind Regards, pd |
[2020-04-30 23:16:40] |
You will only be charged once in this case for the exchange fees.
[2020-04-30 23:49:27] |
Thank you very much for the quick revert
