Date/Time: Thu, 06 Feb 2025 13:58:49 +0000
Fuzzy Depth on DOM replay
View Count: 652
[2020-04-30 20:26:09] |
User135370 - Posts: 162 |
Hi I've noticed a few times that the Depth get's fuzzy when I replay, any idea if this is fixable. I've attached a snapshot |
[2020-04-30 20:45:03] |
I've added another snapshot this time with the market depth window open which seems to be displaying the right depth, the DOM is even more fuzzy in this picture and and you can see that the bid is showing only 5 levels and the Ask 8 levels. Is there a solution to this? |
[2020-04-30 23:13:42] |
This is resolved. Update to the latest version following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-30 23:13:50
[2020-05-01 06:57:24] |
Hi Thank you for that it has fixed the problem however after the update the headings of the time and sales and Quoteboard seem to have blanked out. I went through all types of graphic settings but can't get them to display. I have attached an image to help you see |
[2020-05-01 07:02:55] |
It's OK I went through the support board and found someone mentioned Listbox Header Graphics, it fixed the issue. Thanks for your help |
