Date/Time: Thu, 06 Feb 2025 13:42:34 +0000
My data feed seems to have stopped working.
View Count: 485
[2020-04-30 18:11:06] |
User338887 - Posts: 1 |
Hi there, Need some help with my data feed. I'm using AMP, checked with them a moment ago and everything is fine on their side, but for some reason when I fire up SC, the last data point I can see is quarter past midnight... Can someone help please? Kindest Regards, Tom |
[2020-04-30 18:35:06] |
Did they set up your account on CQG? We also want you to update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
