Date/Time: Thu, 06 Feb 2025 14:19:36 +0000
Reset the system to the default images
View Count: 530
[2020-04-30 18:01:47] |
User866480 - Posts: 2 |
If its not possible to reset the system to the default images then please put in a fix for your system cuz it was working before. If its not possible then simply say so. If its not possible then direct me to where I can download all the images/graphics because some are missing. I already deleted Sierra Charts and re-downloaded so that didn't work.
[2020-04-30 18:33:56] |
It sounds like you are referring to drawing tool buttons on the Control Bar. Refer to the notes for version 2065 here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 It explains what to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-30 18:34:05
