Date/Time: Thu, 06 Feb 2025 13:48:16 +0000
Save chart image problem
View Count: 552
[2020-04-30 16:09:43]
User732945 - Posts: 6
When I attempt to save a chart image (EDIT>SCREEN IMAGES>SAVE CHART TO FILE) everything works as expected but the image is just a black image. No chart details at all. I have searched the board thinking I must have some setting wrong, but can't find anything. Can you point me in the right direction to fix this?
Thanks!
[2020-04-30 18:14:18]
Are you using the OpenGL option in Sierra Chart?:
Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other)
[2020-04-30 18:19:23]
Yes, I was. I just disabled it and the images save correctly.
Thanks for your help!
[2020-04-30 18:52:30]
We will be adding additional logging to determine what the problem is.
Date Time Of Last Edit: 2020-04-30 18:52:51
