Date/Time: Thu, 06 Feb 2025 13:50:25 +0000
SAVING A CHART REPLAY TO SEND
View Count: 530
[2020-04-30 14:15:34] |
User289770 - Posts: 4 |
I want to send a replay to a colleague showing range bars forming with price action. I can not see how to save and send. Any help colleagues? THanks |
[2020-04-30 18:49:09] |
There is no way to do this within Sierra Chart. You would need a 3rd party tool to capture it as video and then send them the video file. You can send a single chart image: Sierra Chart Image Upload Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
