Date/Time: Thu, 06 Feb 2025 14:11:22 +0000
Is it possible to have one chart drive the other charts vertical scroll?
View Count: 710
[2020-04-30 12:24:15] |
mbilyanov - Posts: 62 |
I would like to sync the vertical scale and position of two charts. Basically, ChartRight has some kind of a panning setting that will scroll the vertical axis up and down (keeping last bar visible etc.) and I would like to have ChartLeft follow the Y-axis position. Please see the image attached. Is that possible? I'm investigating the Master Mode, but was not able to achieve this result. |
sc_scroll_sync.PNG / V - Attached On 2020-04-30 12:24:03 UTC - Size: 123.23 KB - 239 views |
[2020-04-30 19:01:00] |
Master Mode is not what you need. You need to use the option for Vertical Scale with the Chart Linking feature. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
