Date/Time: Sat, 12 Sep 2026 19:10:47 +0000
[Programming Help] - Numbers Bars - Volume at price within each bar
View Count: 2482
[2020-04-30 01:24:45]
userSk2 - Posts: 1
I am utilising the Spreadsheet Study to develop signals for conditions met within my manual trading strategy.
Can anyone tell me if there is a way to determine the total/percentage volume within each bar at specific price points or halves/quartiles within the bar range?
I have included a screenshot to illustrate. Being able to use the volume split into either upper/lower half of the bar or quartiles would be a great analysis tool. In the attached example the volume at the central price point would be split between the upper and lower.
Alternate to total volume, percentages in each half/quartile would also work well.
Many thanks...
imageSierra Numbers Bar Volume Split.JPG / V - Attached On 2020-04-30 01:18:30 UTC - Size: 141.87 KB - 645 views
[2020-04-30 09:51:09]
Ackin - Posts: 1865
If you can't find another way through the default sierrachart study or through a spreadsheet I can create it but only as an ACSIL study. Of course, you can use the default values in the spreadsheet for further calculations.
[2021-04-14 08:34:57]
Ackin - Posts: 1865
It's possible download it for free from our CZ/SK forum.
Studies:
Numbers Bars: Sum Mid-H/L Ratio
Numbers Bars: Sum Mid-H/L Ratio Trades
Numbers Bars: Sum Mid-H/L Trades
contact link:
