Date/Time: Mon, 16 Sep 2024 20:42:38 +0000
User Email Questions
View Count: 1134
[2014-01-17 17:08:07] |
Sierra Chart - Max - Posts: 5662 |
I am with TRANSACT FUTURES NOW and I tried to use number bars, it says upgrade required. I need to upgrade to which package ? can you give me trial access for at least 5-10 days, let me try it out . On the chart, I would like to display text with net change from the open/previous close (not the % change) what is the best way to do it. I am using now text study to display previous close I cant figure out how to do the net change Sierra Chart Support |
[2014-01-17 17:35:34] |
1. We can provide you a 15 day trial to Sierra Chart package 5 which includes Numbers Bars. What you need to do is follow through the Direct Account instructions here: https://www.sierrachart.com/RegisterStep1.php When you create your own Sierra Chart account, let us know the Account Name so we can activate it for you. 2. Go to Global Settings >> Customize Chart Header. Add the Daily Net Change field. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-17 17:36:11
