Date/Time: Tue, 04 Nov 2025 18:18:14 +0000
Draw Volume Profile stopped working
View Count: 2190
[2013-04-15 15:16:15]
User87197 - Posts: 65
Hello there. I have package 3 and use volume profile. For some reason "Draw Volume Profile" within the Tools dropdown menu has now been greyed out and I can't access the command via a keyboard shortcut either. The normal Volume By Price study does still work however. Any idea why this may be? I'm sure it's something straightforward.
Many thanks in advance!
[2013-04-15 18:12:45]
This requires package 5:
To change your Sierra Chart service package, select "Help >> Purchase / Account Management" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package".
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your usage time is adjusted.
