Date/Time: Sat, 08 Feb 2025 00:22:28 +0000
FREQUENT disconnections - beginning to become untradeable
View Count: 1938
[2020-05-15 03:19:25]
The Connections section here explains how to disable the use of the Denali feed:
Denali Exchange Data Feed: Connections
[2020-05-15 06:26:11]
We want to make a correction. We said that you may notice less of a problem with CQG.
Actually that is not really true thinking about this some more. With the Denali Exchange Data Feed, there is going to be a much faster detection of a connectivity problem and a faster reconnection as compared to CQG.
Date Time Of Last Edit: 2020-05-15 06:26:24
[2020-05-23 22:32:18]
MitchandSoph - Posts: 33
Hi guys,
I wasn't sure where else to post so just thought I would do it here. I just renewed my Sierra access for the month (paid via Paypal yesterday), but now can't seem to connect to the data feed. It just errors out and tells me to contact customer support for assistance.
Is this due to the introduction of the Denali feed this month? How do I revert this back to the CQG feed and get the connection to work again? Note I have clicked the link above and the Denali feed is disabled in my settings, but I still can't connect to the CQG feed that I had used prior.
Thanks in advance.
Mitch
[2020-05-24 02:01:56]
That error message is coming from CQG. Their server is just not available over the weekend. Sierra Chart provided services, have no interruption over the weekend:
Data/Trading Service Connection and Symbol Issues: 1.7. Unable to Connect Because Server is Not Available over the Weekend
Another reason to switch away from CQG.
Date Time Of Last Edit: 2020-05-24 02:02:30
[2020-06-18 23:01:00]
Hi Team,
Just a few quick questions following up on this and I am out of your hair (at least for a while). I am going to disable all CQG services/subscriptions with Tradovate and activate the Denali feed again for execution/routing. As an aside from the connectivity issues, I've been getting stopped below bar lows as well, which is puzzling, so keen to move away from CQG ASAP as I assume it is a data feed issue.
Could you guys just quickly let me know what I need to do to get this going again? I am 90% sure of what I need to do, but want to make sure I get it right, as am cancelling all CQG related stuff today, and would be great to get a seamless transfer to Denali for execution / routing all in one go.
Also, as an FYI re the connection issues above, I am going to set up Sierra on a VPS service and execute from there. Any internet disruptions on my end (which appear to be super short lived but enough to disconnect me from Sierra) should become a non-issue.
Final question, am I able to run an instance of SC on my home computer for analysis/research, and an instance on the VPS for execution without paying double data fees?
Thanks again... really appreciate the high level of service from you guys.
Cheers,
Mitch
[2020-06-19 18:23:39]
Yes if you are receiving incomplete data, this would be a data feed issue, but we have not known the CQG data feed to have this problem.
At this time, as you might know Tradovate does not support the Sierra Chart Order Routing Service.
See item #2 in the link below for a list of the Brokers / Clearing Firms that support TTFIX service.
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
Regarding the Denali Data Feed:
Denali: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed
Step 1: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements
Documentation for Denali: Denali Exchange Data Feed
Yes you can but if you are using both at the same time only one can receive delayed data unless you pay the exchange fee twice. Instructions to use delayed data:
Delayed Exchange Data Feed
Date Time Of Last Edit: 2020-06-19 18:28:01
