Date/Time: Thu, 06 Feb 2025 13:59:50 +0000
[User Discussion] - Windows in win task bar
View Count: 871
[2020-04-29 17:51:06] |
AKR - Posts: 523 |
is there a setting that allows to only see sierra as program and not each single open window in the windows task bar? I like switching through programs with Alt+Tab but with 20 open sierra windows that is no fun.
[2020-04-29 22:16:58] |
There is the operating system option to combine the taskbar options. Otherwise, the only other option is to not have the other windows detached from the main Sierra Chart window. You can learn more about this here: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-30 12:44:29] |
AKR - Posts: 523 |
yes I know I can combine them on the task bar. i did. but still when I use ALT+TAB I will need to tab through all open sierra windows. expecially and also I will see like this detached windows. so it is no major issue, but by this it takes the oportunity to switch between eg. Sierra and a web browser quickly without using the mouse. |
