Date/Time: Thu, 06 Feb 2025 14:06:32 +0000
vertical price bar
View Count: 506
[2020-04-29 17:10:22] |
User289770 - Posts: 4 |
I am creating a new chart for ESM20_FUT_ CME(m). the digits in the current price are correct but the formatting is off. my prices read, for example, 293900.00 instead of 2939.00 i cannot find any way to recalibrate. My other charts are fine. thanks bob |
[2020-04-30 07:37:47] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After this, follow the instructions here to apply the Symbol Settings to that chart: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
