Date/Time: Thu, 06 Feb 2025 13:59:38 +0000
Study/Price Overlay Region Changing When Re-opening Chartbooks
View Count: 640
[2020-04-29 16:07:44]
User240031 - Posts: 1
Hi SC Support - I have come across a strange issue this week and haven't been able to find it in the search. Chartbook is attached.
I have created a chart in which I only use Region 1 to display all study data. I have Study/Price Overlay studies on this chart, which reference studies from another chart (VWAPs, etc.): http://www.sierrachart.com/image.php?Image=1588176358714.png
However, when I save, close and reopen this chartbook, for some reason all of the Study/Price Overlay studies are set to Region 2. I have to manually reset them all to Region 1, which works temporarily until I close Sierra Chart and then have to do it again when I reopen it.
I have attached a Chartbook here with a single chart. Before I saved this, I set all of the contained studies to Region 1. When you open it, you (should?) see the Study/Price Overlay studies set to Region 2.
Here it is when reopened: http://www.sierrachart.com/image.php?Image=1588176405113.png
Thanks and please let me know if there's anything else I can supply to help diagnose this issue. It's not critical, but a bit frustrating that I have to reset everything manually when I reopen a chart.
Thanks!
attachmentTEST.Cht - Attached On 2020-04-29 16:02:49 UTC - Size: 76.21 KB - 350 views
[2020-04-29 22:27:22]
This is a new problem related to the new Chartbook format, we will resolve this now.
