Date/Time: Thu, 06 Feb 2025 13:54:42 +0000
Initial Balance study issue
View Count: 1339
[2020-04-29 15:44:56]
User968625 - Posts: 260
see the image the Initial Balance study is not working right next to 30 mins TPO. It is working fine, with the same setting on other charts but with the TPO chart is just not working right.
The IBH and IBL seems to keep extending with the day (I am doing this because there is no way to have IB label display like this in the TPO study itself as I understand)
can someone help
Date Time Of Last Edit: 2020-04-29 16:23:32
imageIB issue..png / V - Attached On 2020-04-29 15:44:27 UTC - Size: 49.77 KB - 229 views
[2020-04-29 22:29:04]
You cannot use the Initial Balance Study with TPO Profile study. Refer to the information here:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart
Instead you need to use the Initial Balance options within the TPO Profile study. Refer to the documentation starting here:
Time Price Opportunity (TPO) Profile Charts: Initial Balance Range
Date Time Of Last Edit: 2020-04-29 22:29:10
[2020-04-29 22:41:43]
ok, two things:
1- But the IB in the TPO doesn't display the subgraphs names when I chose it. like I would like to see IBH or IBL label (right for example -right, left, label, ---etc.
the only way I see it is through the vertical bars but I would like to see the names displayed?
2-it is funny as when I study overlayed from another tick charts, it doesn't exactly align with the vertical bars, not sure how is that possible?
[2020-04-30 12:01:14]
Ok solved, the only way I was able to do this as to have the IB level on another TIME chart was periods ending at the same time as IB (for example, won't work on a tick chart or a 39 mins chart if you use such a thing) then overlay price/study. hope that helps someone later
