Date/Time: Thu, 06 Feb 2025 13:38:10 +0000
New Quantity keyboard shortcut and control bar command
View Count: 923
[2020-04-29 15:41:57] |
seandunaway - Posts: 316 |
I love the New Quantity dialog (attached) Would you please consider adding a keyboard shortcut and control bar command to open it and set the chart's quantity? (a neat bonus would be a Special Items control bar command with the current quantity set as the button caption) |
new quantity.png / V - Attached On 2020-04-29 15:41:49 UTC - Size: 4 KB - 275 views |
[2020-04-29 22:27:53] |
There already are Control Bar buttons that can change the quantity to a preset quantity: Basic Trading and the Trade Window: Control Bar Buttons for Preset Order Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-29 22:28:01
