Date/Time: Thu, 06 Feb 2025 13:41:37 +0000
Dome Control Bar
View Count: 481
[2020-04-29 14:30:01] |
PaulC - Posts: 16 |
Is it possible to restore the old Control bar associated with the dome showing yesterday close, current vol C and D arrows etc...
[2020-04-29 22:34:39] |
We are gradually working on adding a customizable header for Trading DOMs which will be multiple lines and can support fields like these.
