Date/Time: Thu, 06 Feb 2025 13:39:29 +0000
Chart stutters back and forth up and down while the scale on the side alters numbers.
View Count: 568
[2020-04-29 14:15:45] |
User339484 - Posts: 71 |
Not sure how to explain it perfectly but the scale on the side switches numbers so everytime the price changes the chart is bouncing up and down very slightly. I can record a video if needed.
[2020-04-29 14:44:46] |
Chris_uk - Posts: 89 |
Hi, If you right-click the scale is it set to 'Constant Range'? Try selecting Automatic or one of the User-Defined options. This stops what you're experiencing for me. I only notice it when using the Numbers Bars study. Cheers Date Time Of Last Edit: 2020-04-29 14:47:45
[2020-04-29 22:39:37] |
Refer to the documentation here for this: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
