Date/Time: Thu, 06 Feb 2025 13:50:47 +0000
[User Discussion] - Large Increase/Decrease chart spacing pixels
View Count: 814
[2020-04-29 10:40:21] |
herjarsa - Posts: 10 |
Large Increase/Decrease chart spacing pixels is by default at 5, I want the time scale not to make those jumps, I set it to 1 but it doesn't make any changes.
[2020-04-30 00:09:38] |
That setting is functional. We verified that. If you only want to make a change by one pixel, then do not use Large Increase/Decrease Spacing and instead change the spacing by a single pixel. This is fully documented here: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-30 11:14:13] |
What I want is for the time scale to move smoothly as NinjaTrader does without those sudden jumps, as shown in the video. Thank you https://www.screencast.com/t/ht7UvZCLOOlS |
