Date/Time: Thu, 06 Feb 2025 11:43:10 +0000
Double Click On Drawing Brings Up Drawing Properties
View Count: 675
[2020-04-29 10:33:55] |
herjarsa - Posts: 10 |
Global Settings - Tools Settings - Double Click On Drawing Brings Up Drawing Properties is enabled, but double clicking on the drawings does not enter properties, double clicking enables you to modify or adjust.
[2020-04-29 11:21:29] |
You also need to have Support Left Click To Select Chart Drawings enabled. We will add this to the documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
