Date/Time: Thu, 06 Feb 2025 11:36:08 +0000
[User Discussion] - color bar based on alert not plotting values
View Count: 511
[2020-04-29 07:23:02] |
arruga - Posts: 253 |
Got an alert formula. If select to graph point on graph draw style, the candles are identified correctly as per my alert formula. The 'output when condition is true value' is set to default, 1, i.e. it's binary 1 when TRUE, 0 when false' I want to plot this as a line graph of 0 and 1 in the 2nd chart region.... Nothing is being graphed If I use a custom value instead... same deal... nothing If I select the main chart... again, nothing. If I use a spreadsheet study, the 1 and zeros are written to the spreadsheet, but when selecting to graph that column onto the chart, regardless the chart region... nothing is graphed Any idea on what could lead to this behaviour of not plotting anything? I can see the region was added and it has a NaN as Y axis label, but nothing's being graphed. Like I said, candles are identified corretly so alert is working fine... those 1 and 0 values are event written to a spreadsheet... they're just not graphed. thanks |
