Date/Time: Thu, 06 Feb 2025 13:52:25 +0000
Bid / Ask stop order execution LMAX
View Count: 557
[2020-04-29 06:55:32] |
User513662 - Posts: 90 |
Hello, LMAX have the following option within their account settings panel: Use Bid/Offer Stops When checked, new Sell Stops will trigger when the Best Ask meets the Stop Level and Buy Stops will trigger when the Best Bid meets the Stop Level. When unchecked, new Sell Stops will trigger when the Best Bid meets the Stop Level and Buy Stops will trigger when the Best Ask meets the Stop Level I am toggling between this being checked and unchecked and I am not seeing any difference with execution on Sierra Chart. Buy stops are always being triggered by the Bid, and Sell stops are always being triggered by the ask, no matter what the setting I have inside LMAX. Is there a setting in SC for this? I cannot find one sorry. |
[2020-04-29 23:57:24] |
This is not controllable. It is preset by the background FIX connection.
