Date/Time: Thu, 06 Feb 2025 13:46:27 +0000
Triggered Trailing Stop problem
View Count: 534
[2020-04-29 06:07:31] |
User432142 - Posts: 44 |
"If I set Triggered Trailing Stop without any Trail to BE settings, then the TTS works as expected. But if I add the Trail to BE component, then the TTS does not respect the Trail Offset = 2 setting. Rather it trails at 5 ticks. It appears to be using the Stop Offset value instead. If I remove the Trail to BE settings, then the TTS again works as expected." |
2020-04-28_15-56-46.jpg / V - Attached On 2020-04-29 06:06:33 UTC - Size: 69.14 KB - 241 views |
[2020-04-29 18:16:32] |
We will try to get to this issue today and see what the problem is.
[2020-04-30 11:45:02] |
This is resolved. We are putting out version 2098.
