Date/Time: Mon, 25 Nov 2024 05:51:16 +0000
SSL socked shutdown multiple times
View Count: 1554
[2014-01-17 09:11:38] |
User60591 - Posts: 39 |
Hi, I'm getting folowing message several times during the day, and in the past days I've been automaticly disconected and again connected to the feed also several times a day. LOG Message: Socket closed. No error. | 2014-01-17 10:02:38 The SSL socket was shut down successfully. | 2014-01-17 10:02:38 CTS Historical FIX Session: Socket connection was closed without any logout messages sent or received. | 2014-01-17 10:02:38 CTS Historical FIX Session: Disconnected. | 2014-01-17 10:02:38 Im connected to CTS. Can you pls tell me why is thiss happening because I'm testing spreadsheet automaed system and planning to go live in couple of weeks. I don't want to be experiencing multiple disconectins per day. thnx |
[2014-01-17 09:32:37] |
This indicates the remote CTS server closed the connection. What the reason is we do not know. Sierra Chart will reconnect five seconds later. We could reduce the reconnect time.
[2014-01-17 15:05:13] |
Ok but it happens to me several time me in a day, and if I will run in future automatic strategy live it's not a good thing.
[2014-01-17 17:33:24] |
In the next release of Sierra Chart we will reduce the reconnect time. If you are getting disconnected from the server, could you contact CTS about this here: http://www.ctsfutures.com/contact.aspx Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
