Date/Time: Thu, 06 Feb 2025 11:46:02 +0000
TPO profile blank
View Count: 800
[2020-04-29 03:38:59] |
User284416 - Posts: 27 |
Hello I've just paid for subscirption but discovered that TPO profile went blank after that. it looks like this https://gyazo.com/9ab37bdfddacc05a5692d05cc5350506 and doesn't even have axis. but if i remove study it looks ok with all the drawings i had on it and axis in place https://gyazo.com/347a2ea588ba86c62c6b7243c427a1e4. tried to remove and add study again, tried ticking "display as main chart graph", tried restart - nothing helped |
[2020-04-29 04:47:12] |
For TPO Profile Charts, you need to change your Sierra Chart service package to the Advanced package 5. Instructions: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-29 04:47:37
