Date/Time: Thu, 06 Feb 2025 11:41:45 +0000
Volume / Length in Ticks in decimal
View Count: 608
[2020-04-29 01:52:46] |
User745789 - Posts: 356 |
For Zig Zag study. I know you are not accepting requests. But please consider offering 2 decimal places for ZigZag Volume / Length. Needed for instruments with low volume v.s high tick count. Eg Hang Seng Futures, where the numerator can be smaller than the denominator, particularly if the volume accumulated is BidVolume-AskVolume difference. Currently 20 volume / 50 ticks displays as 0. And other fractional quotients display as integers, therefore losing all detail. |
[2020-04-29 05:43:51] |
You can easily modify this study to meet your requirements. For instructions, refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
