Date/Time: Thu, 06 Feb 2025 12:00:22 +0000
Copying settings templates from another version of Sierra
View Count: 581
[2020-04-28 21:50:24] |
User525965 - Posts: 153 |
Hi, I have an additional brokerage account i want to set up with sierra chart. I'm downloaded a 2nd version of the software. I want all my settings and chart templates to be the same as the one i already have set up. Is there an easy way to duplicate this to the new one?
[2020-04-29 05:38:36] |
Yes. Refer to this help topic: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
