Date/Time: Thu, 06 Feb 2025 11:49:59 +0000
using of
View Count: 460
[2020-04-28 19:53:09] |
User404467 - Posts: 3 |
Hello, Do I need to turn on the setting "Use Order Fill Calculated Trade Position Data", if I use Denali Data Feed and AMP broker? Thank you |
[2020-04-28 20:05:38] |
No that is not required.
