Date/Time: Mon, 21 Sep 2026 17:45:02 +0000
Study seems broken - High/Low for TimePeriod Extended
View Count: 776
| [2020-04-28 18:39:37] |
| User71961 - Posts: 144 |
charting ES futures bar period type: volume setting: 20,000 contracts per candle 30 days add study: High/Low for TimePeriod Extended start time 9:30 end time 9:31 line stop time 23:59:59 this shows the high/low lines for prior days, but not the current day. this used to work, but then i updated to current version of SC 2091 and it broke. please help? |
| [2020-04-28 18:44:26] |
Provide that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-28 18:44:40
| [2020-04-28 18:58:52] |
chartbook attached with study: High/Low for TimePeriod Extended
| [2020-04-29 14:01:57] |
| John - SC Support - Posts: 47953 |
The problem is that you are using a Volume based chart, and therefore there may not be a bar that has a start time of 09:30:00. In those cases, it is not calculating the High/Low for that day. We also went back to release 2028 and we are seeing the same results, so this is not something new. Really, the best way to do what you want is to have a 1 minute chart for that symbol and put the High/Low for Time Period - Extended on that chart and then use the Study/Price Overlay to overlay those results to your Volume based chart. There is information in the following documentation about why using this study on a non-time based chart will lead to inaccuracies, as well as how to use the Study/Price Overlay to get what you need: High/Low for Time Period - Extended For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
