Date/Time: Thu, 06 Feb 2025 12:06:56 +0000
Select Elements
View Count: 591
[2020-04-28 15:02:24]
herjarsa - Posts: 10
How can I modify a drawing element that is inside another one? example I draw a horizontal line and then above that line a rectangle, how do I enter the properties of the horizontal line? when I try to select the line the rectangle is always selected or both are selected showing a number. thank you
[2020-04-28 15:40:08]
JohnR - User831573 - Posts: 309
Try Menu -> Tools -> Manage Chart Drawings Window (Ctrl-Alt-M) From there you can select the drawn object and press the properties window.
That is one way I know of.
JohnR
[2020-04-28 19:45:16]
Refer to the information here for Converging Drawings and how to select a specific drawing using the pointer. Note that this section is about Moving Drawings, but it applies to all the functions where you are trying to select a specific drawing where there are multiple drawings present:
Chart Drawing Tools: Converging Drawings
Regarding rectangle drawings, disable this option:
Chart Drawing Tools: Support Interior Rectangle Selection (Global Settings >> Tool Settings >> General >> Tool Options)
Date Time Of Last Edit: 2020-04-29 05:36:09
