Date/Time: Thu, 06 Feb 2025 13:37:07 +0000
Trading Eurex via TT
View Count: 783
[2020-04-28 13:02:06] |
Marmany - Posts: 308 |
Orders on Eurex are now being rejected due to "Insufficient permissions : route does not exist for clientCompId". Took this up with broker, Dorman, to be informed: "Looks like TT is charging $250 per month for Eurex exchange to all Dorman clients so I believe this is the issue as all Eurex exchanges have been closed off on TT unless customer is willing to pay for the $250 per month Eurex fee." I note on another thread that Sierra is close to having Eurex on the Denali feed. Will that also be subject to the $250 / month charge? |
[2020-04-28 18:27:18] |
Could you check with AMP to see if they have this fee. Otherwise, the only other choice would be CQG or Interactive Brokers for EUREX. Will that also be subject to the $250 / month charge? No definitely not in regards to market data.
[2020-04-28 18:28:16] |
We are checking with AMP about this.
[2020-04-28 18:29:05] |
AMP says there is no 250USD fee/month when using TT.
[2020-04-28 18:43:46] |
So for EUREX on TT what we know of where there is no fee is AMP or Stage 5 through Advantage. This is what we know of so far.
[2020-05-01 04:52:19] |
T44 - Posts: 363 |
Can affected Eurex traders at Dorman switch back to CQG WEB API via Sierra Chart?
[2020-05-01 06:18:38] |
Yes will be fine.
