Date/Time: Thu, 06 Feb 2025 12:13:14 +0000
Trailstop bar by bar
View Count: 810
[2020-04-28 12:30:47] |
User954479 - Posts: 1 |
hi! is a trailstop bar by bar (+ offset) available? (a stop - in case you are short - that follows the last high of a candle, bar by bar, with an offset of + x) thx |
[2020-04-28 20:14:04] |
Take a look at this study that can do what you are asking: Trade Management by Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
