Date/Time: Sun, 04 Oct 2026 08:21:28 +0000
Control Bar buttons all changed after downloading current version
View Count: 796
| [2020-04-28 08:55:42] |
| User629461 - Posts: 213 |
Just downloaded current version and all the Control Bar buttons have changed from previously defaults (sjhort text to long text). First, how do change this in an efficient manner (ie not resetting each and every button). Second, why did you need to change this? Thanks |
| [2020-04-28 19:03:07] |
We have solved this in the latest prerelease. We have been working on the captions for Control Bar buttons to be more descriptive short names rather than just abbreviations. However, we know that users have become accustomed to the abbreviations and we have added the old short captions back with an option to use them through Global Settings >> Customize Control Bars >> Control Bar # >> Short Captions. We are still working out the implementation details of this in relation to having set custom captions. So this is still being worked on.
Instructions to update to the prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-04-29 00:29:25] |
Thanks - Sort of worked but not entirely. Some buttons show short caption txt the same as long caption. Eg Find Symbol - previous: FS; now: Find Symb for long and short. And I used to have a mix of Txt and Images for buttons. Now its nearly all text. It would be best if updates just leave the Contol Bar buttons as is and users can change optionally if desired. I can see I'm going to have to spend an hour or more of my time fixing this. Date Time Of Last Edit: 2020-04-29 00:30:04
