Date/Time: Fri, 07 Feb 2025 04:38:27 +0000
ADM
View Count: 710
[2020-04-27 18:43:14]
Robert Wojczak - Posts: 147
I just received the following that ADM will not support the TT connection wit Denaili which is what you guys suggested.. I cannot hook up my Rithmic data .. I cant seem to get it to work and you guys wont help me
What do you suggest
Robert,
ADMIS has decided that they are not going to support the new SierraChart Data connection.
So I would suggest using the existing Rithmic Data set up as it currently is formatted, or contact SierraCharts and see if they have any other data that can be used.
Please log into SierraChart with the Rithmic information and let me know if it is still working. The Rithmic Connection is still enabled and collecting data. I just checked.
[2020-04-27 19:25:44]
We just hope everything works well with you with Rithmic. You are going to have to pay the exchange fees a second time through Rithmic for the data when using Sierra Chart.
The first thing we want you to do is to update Sierra Chart to the current version:
In the installer window, enable "Install Optional Components" and then try connecting to Rithmic and if there is a problem provide the Message Log:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2020-04-27 19:26:19
[2020-04-27 19:34:39]
I am trying to do what you suggested. I want to you Sierra Charts data and order routing, And not pay 2 fees ADM will not support your connection
[2020-04-27 20:19:04]
Okay another solution is to open a $100 account with AMP:
Easy Solution to CME Funded Trading Account Requirement
That might be the best thing to do.
[2020-04-27 20:23:31]
so how does that let me trade with my ADM account?
[2020-04-27 20:25:43]
I should not have to open another account. I'm not going to do that.... I want to use my ADM account with your feed. Thats what you guys told me to do last week. Now you are telling me to open another account. You guys need to sort this out with ADM not have me open another account
[2020-04-27 20:31:52]
You are not doing your trading through Sierra Chart, so this other account is not going to be relevant. It just simply is used to authorize the CME data.
But this did not work out as expected with ADM.
We have no control over the decisions of clearing firms and they have good reasons for why they do what they do.
We did say we will help you with Rithmic so can you just follow our instructions in post #2 above regarding Rithmic.
Date Time Of Last Edit: 2020-04-27 20:32:14
[2020-05-24 16:02:23]
theunknowntrader - Posts: 112
So ADM will not be supported by Sierra.
Great to hear. You guys should post this in the boards as ADM is the best capitalized broker of all.
